Local Garage Door Fix in Fresno TX
Garage doors are an important entryway into your home or business, so make sure you choose the experts at Garage Door Repair for all your repair, replacement and installation needs. We know the qualities that are important in choosing a door like: durability, safety, security, style and energy-efficient. That’s why, with our expert knowledge, we can help you select the right door to fit your needs and budget.
If the door works but you have trouble opening or closing it, worn springs may be the culprit. If the springs look worn, you should have a professional look at them. Working on springs yourself can be dangerous since they are under high tension. The same goes for worn cables, which attach the springs to the bottom of the door and provide the proper leverage for lifting. If they are beginning to fray, this is pretty serious. Loose brackets can be another reason you have trouble opening your garage door. The brackets hold the cable to the door and thus are under a lot of pressure. You should almost never mess with these yourself for the reasons stated above.
If you have a problem with your garage door opener, Garage Door Repair has years of experience taking care of our residential customers garage door openers, and commercial automatic openers and closers |
